HELP! How to replace clutch drum on FS 74 string trimmer
sieb21
  • / HELP! How to replace clutch drum on FS 74 string trimmer
Can anyone walk me through how to remove the clutch drum from the fan housing on an FS74 string trimmer?
Thanks in advance.
Jim
Boobala
Thanks in advance.
Jim
Sorry Sieb... I dont have a service manual but I did have this Parts Listing .. Sometimes this is all I need to get
the job done , hope this is of some help ...
View attachment 31428...View attachment 31429
The drum is held in by the circlip
Get your digital camera out and photograph the unit every time you take a part off.
The front & back simply pull apart then the circlip comes out and the drum comes off
If the drum is gone then usually the springs on the clutch are gone as well.
usual practice is drum & clutch as a unit.
sieb21
Thank you for that information! My next problem is how did I get the circlip out!? It is recessed deep in the fan housing. Any suggestions? Special tools needed??
BlazNT
With something like this.
Boobala
NO...NO...NO.. Chuck......... It's NOT a Cir-clip It's an expansion -contraction spring clip...
usually you can get a hook tool under the center of the clip and strong pulling will pop it free ( gotta be careful the da** thing don't go flying across the room ) or sometimes you can get 2 small screwdriver blades under the ends and pop up they can be real boogers at times ...anyway that's MY method of removal ..Boobala
BlazNT
I guess I should have included a picture of a long flat head screw driver. I push the to ends apart then use a screw driver on the back side to pry it out. I always put my hand over it so when it goes flying it hits my hand.
