24* vs 15* trailer ramp for a zero turn?
mikeypizano
I need to find a trailer for my Toro SS4225, and all I can find is one with a 24* ramp, Toro book says I need 15*.
Will this work?
Will this work?
It will work if you let air out of the trailer tires until they are flat then un-hook the trailer and jack the tongue up far enough. If you purchase one of these air hoses and an adapter to fit one of the mower spark plug holes the mower engine can be used to inflate the tires back to recommended psi, then don't forget to hook the trailer back to the ball hitch and you be on your way.
OK so I do not understand this question. Is this for width of ramp or length? In either case I would see bigger is better. Longer would give you a better angle to not scrape deck when loading trailer and wider would give you less chance of falling off.
The angle of the gate. Toro wants a 15* angle, best I can find is 24.
