mikeypizano
I need to find a trailer for my Toro SS4225, and all I can find is one with a 24* ramp, Toro book says I need 15*.
Will this work?
Will this work?
Will this work?
OK so I do not understand this question. Is this for width of ramp or length? In either case I would see bigger is better. Longer would give you a better angle to not scrape deck when loading trailer and wider would give you less chance of falling off.
OK so if you raise the tung of the trailer the angle gets smaller. 2 way I can think of is smaller tires or change the height of the adapter to you trailer hitch. Mine is a 2" drop then flip it over and its a 1" raise. Or you could buy something like this. http://m.autoanything.com/towing/trimax-razor-adjustable-hitch-ball-mount.
With all that being said have you hooked it to your hitch to verify the angle?
I would suggest going to a trailer place hooking it up first and then check in the angle.
