Blades What do you guys sharpen your blades with?
Remove blade, install in vice, clean it with a power wire brush, sharpen it with a angle grinder, balance blade, reinstall.
I do the same, though I have been told that I should swap my metal grinder with a a more of a sandpaper grinding wheel. I heard you dont lose as much blade that way. So next time I go to home depot I'm going to get one and try it out.
Same as above except I scrape instead of brush and I use a flap disk in my angle grinder to sharpen with. It runs cooler and leaves a nice edge. Balance every time.
I use a 4 1/2 inch hand grinder with a vice to hold the blade.
Same here. I use G6 Gator blades and the grinding wheel leaves a very uneven edge, but it gets blasted flat by all the sand and grass clippings going over the blade.
The guy who sharpens mine uses a 6" side grinder with a large disc on it.
Tried all these methods and ended up using a bench belt sander due to a more consistent finish.
