jekjr
Not correct.
Curved shafts come in both directions.
I can buy left hand drive shafts and right hand drive shafts
Because strait shaft trimmers usually have a solid shaft they can take a lot heavier load on the head.
Curved shafts use a twisted cable so can not be used with high load heads
Curious on that one. For a curved shaft trimmer to operate a different direction that would mean that the motor has to run one direction or the other since every one I ever saw ran the way that the motor rotated.
The reason a straight shaft trimmer runs opposite is that it has two gears in the shaft at the bottom.......
