2 and a half years with mine now. Only some adjustments needed in the beginning, no problems to talk about. Still only have about 60 hours so far. Lots of cutting so far this season though.
What engine does the new model come with?
did you buy a machine with kawasaki engine? they switched to kohler this year.
i personally think kawasaki is a better engine.
I got the the only kawasaki engine in 8 dealerships. thanks for the feedback
would you treat the underside of the deck with anything?
thanks
Just for added insurance before I ever turned my mower on (last 3 I owned) I coat the underside of the deck with ez slide - if you have ever tired to stand in a gravity wagon painted with this stuff you will understand it is very slickNo, did not treat the underside of the deck. Got a set of ramps and knock off some big chunks after a damp cut so as not to stink up my garage too much. I don't cut wet.
Neighbor has a base Hustler 52", he is a morning cutter. He puts out a cloud of water when cutting.
http://www.tractorsupply.com/tsc/product/ez-slide-graphite-based-coating-1-gal?cm_vc=-10005
