HRC216
I have 3 HRC mowers. The yellow blade clutch button pops randomly disengaging the blades. Is there an issue with these or can they be adjusted?
Absolutely fixable, but share the full serial numbers off the back of the mower deck with me, and I'll double-check for any service details:
Serial numbers are MAKA 1077993, MAKA 1059147, MAKA 1174193. All are HRC2163HXA.
Could you tell me how to adjust ground speed control as well?
Thanks Robert!
Thanks mechanic mark!
Tim
Tim
Tim, send me a private message with your email address. The two older HRCs are in a batch that may have an issue with the Roto-Stop lever disengaging, either due to a a misalignment, or defective handlebar. I'll send you the inspection procedure, and it will explain how to check if it a simple mechanical adjustment or if the handlebar needs replacement. I'll also send you the detailed bulletin on all HST inspection, adjustments, etc.
