I have a 2004 JD L130 with the Kohler 23hp Command engine. I was driving the mower (deck not engaged) when it died. I have no power even to the hour meter. Ive check the main fuse, battery, ignition switch, brake switch, seat switch, PTO clutch & switch with no luck of any problems other than the headlight terminal on the ignition not working per VOM. HELP!!!!
