Ok I purchased my mower the first of May of this year,it had about 1 gallon of fuel from the dealer but did not use the mower until the the middle of May waiting on replacement tires "new tires had cracks" after getting the new tires I added a gallon of 93 gasoline,I used the mower for about 1.5 hours and at the end of June filled it up with 93,used about a half tank and filled it up again the end of July,now with 6.5 hours on the mower I had about a gallon of fuel left from the last fill up so today I purchased 2 gallons and added to the tank.Is it possible my fuel is bad even though I have been topping it off? We have had a lot of rain and a large portion of my yard is wet so I only cut the front with the Deere and use my old mower for the wet mess that's why my hours are low.Every week since I purchased the mower I would start it up and drive it just to keep fuel from setting in the carb bowl and to keep the battery charged.My dealer is clueless after speaking with him,he tends to lean toward trash in the bowl seeing my issue is intermittent,he is a week behind in work and said it would be next week before he could look at it.
