Ric
I know this is an old thread but I thought i would give you guys an update. In all these posts I set my sites too high on mowers that are too expensive and would most likely cause me to take home less money. I decided to go with the Toro Turfmaster the commercial 30" push mower. I have two cause my brother works with me. I wanted and still do either the Scag SWZT, Snapper Pro walk behind, or the Scag V-Ride. After considering my financial situation the fact that I am not making too much money I needed to go with something less expensive. After only owning Home Owner Toro push mowers mainly the Toro SR4 it is amazing to me how great the cut is from the turfmaster and how well it mulches. It probably mulches the grass into pieces 4x times smaller at least. I will post some pictures when I get the chance.
I also wanted to thank all of you guys for all your help I have learned so much thanks to you I feel like I have enough knowledge to buy a bigger commercial mower when the time comes.
I can't see how setting your sites to high on mowers that are too expensive would most likely cause you to take home less money. You already seen the difference in productivity between the Toro SR4 and the Turf-Master and the gains you've made with the Turf-Master mowers and with a good Stander or ZTR you can triple that productivity and the money your making now.
