Shughes717
Your right, I need to be realistic about this. No matter what I get its going to work just fine. I stopped by the John Deere dealer on the way home and looked at the Z235, nice mower and seems pretty well built. Its not like I'm going to be traveling with this, I will bring it home and its life will consist of going in and out of a shed. I'm going to stop by a Toro dealer tomorrow then take a look at Hustler over the weekend. With the idea that I should be looking for the best engine that I can get for the price range, Kawasaki>Briggs>John Deere>Kohler in that order?
I am not a fan of the low end Briggs engines. Their commercial turf engines seem to be pretty good, and the vanguard is one of the best commercial engines out there in my opinion, but both of those options are way out of your budget. The fr series Kawasaki is a very good engine. I have also had good luck with kohler command engines. You will get many different opinions on that question. You won't be putting a lot of stress on whatever engine you go with, so truthfully you should be ok with whatever engine you go with.
