Shughes717
- Jun 12, 2014
- 1,230
Ok bought the MZT 52 yesterday and cut with it. All I can say is amazing. Like I said I use a LazerCut 60 at my job so this is not my first zero turn.
This MZT has the 28 hp Briggs engine. There are a few other reviews of this lawnmower so I wont bore you with mine. But I will say that it is very powerful and fast! It is well built. The sticks took a little getting use to because they are stiffer than the Exmark. The hour meter only runs when the blades are engaged also. There a plenty grease fittings so maintenance will be easy. I read in another review that the trans wines kinda loud. This is true when the engine is not running at high rpms.
I have no complaints and I am pleased with the purchase. Thanks to everyone that replied.
Thanks for keeping us posted. I don't get bored with member's reviews of mowers. I for one, want to read reviews from others about the mowers they purchased. You haven't had it long enough to give us an extensive review, so continue to keep us posted if you don't mind. Would like to read the positives as well as the negatives as you run your mower over the years. Btw, did the dealer negotiate with you or did he stay firm at the price he initially gave you?
