Spindles on 48" tiger cub
STOP over greasing these spindles!!!!!
When greasing them, you stop when the grease first shows at the relief valve.
Mow with this machine and let the spindles settle.
A grease gun puts out more grease than the relief valve can vent out. If you continue to pump in grease, you will blow out the seals!!!!
Ok M.M. Thanks for advise...will stop and see what happens.:thumbsup:
