The problem you would have is the filter size. It would have to be as large as the spin on oil filter you run on your mower, enough to hold gas and water separately and filter elements which separate the water as well as remove any contamination. My guess is that it wouldn't be cost effective on a mower, that's why the manufacturer doesn't install them.
Not quite.
under the fuel tap on most Honda engnes is a "debris trap" which wii & does trap water.
Problem is no one ever seems to bother to empty it.
Aftermarket carbs have the same tap but no sediment / water bowl underneath it.
