$ 13 meter for pH, moisture, and light--- seems worth the price
Have one it sucks for ph .. however the moisture and light is handy for telling customers to water more lol
A while back I looked hard at home based Ph meters and found the threshold to be about $100 for a decent one. What stopped me was the tricky calibration required.
They also make a soil testing kit
Yes, but I like the readings !
This company also makes a soil testing kit. Will try it.
An odd thing happened after two hours spreading iron sulfate. My tongue swelled and one side looked like a red chili pepper. Scary . I had trouble speaking. So I went on line. The stuff can cause allergic reactions including swelling of throat. The bag said use a face mask which I ignored. No more. (Wife said my no speech problem was not really a problem) :laughing:
You can select a speech problem any time you desire. Practice this on your witty wife. :laughing: And it works re-markedly well during telemarketing calls if you be plagued with them. Fun too, but if you laugh it sure blows your cover.
The Technique: press your tongue tip to your front teeth and keep it there with a little pressure. When answering the phone your " hello " becomes " helwoooow " . I get severely reprimanded when my daughter calls.
I've used Encap & Ironite with no problems.
I used to raise fishing worms and monitored ph weekly. I found those cheap soil testers either didn't work, some were inaccurate or they weren't accurate for long. I went to only water ph meters but a decent one is at least $60. Calibrated with solution 7ph and the other solution was 5ph I believe. In Georgia, the extension agency will analyze soil samples for a fee. You may not have something like that in your area though.
Ya mine was never accurate it thinks all my lawns are perfect lol. I spread iron all the time no mask never any problems
