twall
About the plugs.....if they get fouled just spray the electrode with wd40 and clean with a wire brush and they'll work like new
I did say carb cleaner - that works better...:biggrin:
CajunCub said:twall, are you on drugs or just f------ with this guy?:laughing: WD40 has NO place on a spark plug! For that matter anywhere on a mower at all...maybe a throttle cable.
So,Your mower that is producing "white smoke", is what I would call unburned fuel & too much oil in it. The simplest answer is usually the right one, Drain your oil....and refill it to the right level. (use 10w30) Change the spark plug(with a NEW one) and replace the air filter!
Wd-40 works GREAT on spark plugs and just about everywhere on mowers....if u wanna buy a new spark plugs instead of being smart and utilizing the benefits of wd-40 that's ur loss,,,I've had tons of fouled plugs and sprayed them with it and the engines fire up everytime
When it won't start, or loses power......hard to say how long. Just keep a spare handy. Sometimes, you can just clean off the oil off the electrodes with carb cleaner.
Let us know if the smoke clears up, ok?
