GasSniffer
Bought one of these the other day.
http://www.homedepot.com/catalog/pdfImages/fa/fa35541d-2b4c-43cf-8517-cb9c978f23dd.pdf
Was wondering about pumps... I know Ryobi uses the Homelite/Ryobi 308494058 pump on these pressure washers.
308653064 Ryobi RY80940B Pressure Washer Pump w/ Thermal Release Valve at homegardenpro.com
I know the Honda GCV190 on this unit is extremely reliable... It is the pump that I am worried about. The manual provides minimal detail about the pump and maintenance to the pump giving a generic statement:
Will I be able to ever replace this pump with another similar type pump? If so what can I use and how much can I be expected to spend? Any recommendations on maintenance for this unit?
Thanks in advance for any advice.
The pump on this product was lubricated with a sufficient amount of high grade lubricant for the life of the unit under normal operating conditions. Therefore, no further lubrication is required.
