Well tried removing the spark plug and the motor wouldnt spin over by hand or starter tried removing the starter and still wouldntbtirn over by hand and nother wraped arournd the crank shaft. I also know that it didnt throw a rod because I didn't see anyhole in the side of the motor so it leaves me to believe that it is the connecting rod but it could also be miltiple things it also could of not had any oild pressure either and it licked up but. What do you guys think also how much would this cost if i brought it into a shop. Please repond back please thanks. Also the motor is a 2007 briggs intek 20hp signal cylinder.
