lawn mower fanatic
- Jun 8, 2012
- 6,749
No I don't believe it is the most efficient way to mow a lawn. Since when is going over a lawn twice every other pass to bend grass the opposite directions to reflect light efficient? All you do is waste time and time is money. I don't no where mowing in circles came from but nobody does that either, in-fact I've never seen a homeowner lawn here you could mower in a circle. You can do a good job on a lawn with any mower, a Stander,ZTR, WB or push because they all will do a good job but it really doesn't come down to the lawn being mowed as much as it does the detail work.
You said I probably won't be able to stripe with the Toro because with side discharge I might have to go in a clockwise circle, why would you do that? With G5 or G6 blades you can mow the direction you want because your clippings will be so fine your not going to see them and your lawn will look good. There are plenty of good mowers you can get for under 6K and be more productive than some of the people are talkin about.
One of the reasons I am hesitant about the 36 is because of the discharge. After using my Billy goat, it was just a mess, and I swore I would never side discharge again. So if you think it should be ok that's good. What about the Toro mulching blades. Just as good as Gator Blades?
