Bobby Boyd
- Jan 10, 2012
- Threads
- 34
- 99
I have a 61 inch turf tiger. How do I change the deck belt? What releases the belt tension?
Thanks,
-bobby
			Thanks,
-bobby
Hi Bobby,
Look in the parts manual for your deck, you will see a tensioner arm with a pulley mounted on it and the arm has a large spring pulling on it. There is a square hole stamped into the tensioner arm. Using a 1/2" drive breaker bar with a long enough extension, you can turn the arm enough to release the belt and remove it from the deck. When I do this, I have a 2nd person turning the breaker bar so I can grab the belt and pull it away from the tensioner pulley and remove it. If you have any doubts about belt alignment, take some pics before you remove the belt. You can install the new belt around most of the pulleys and have the 2nd person turn the tensioner, lineup the belt over the tensioner pulley and then release the tensioner.
If you have a collection system on your machine, the blower drive belt must be removed first.
Mad Mackie in CT:laughing::biggrin::smile:
We are having a heat wave!!! It's up to 12 degrees!!!:laughing:
