jekjr
all you have to do is locate where the screws are that holds the ply wood in place and line up there.I'm going to try to install some racks on Monday or tuesday. But the walls on the inside of the trailer is wood from the floor all the way to the ceiling. How do I locate the studs? Buy a big magnet or what?
We are in our second year of using an enclosed trailer. It has a lot of pros and some cons I guess.
Hauling as much equipment as we haul and unloading as much as we do ours has taken a pounding. I plan to try to make one more year with the one we have and then look at possibly updating to one that is a little heavier.
Mine is 16' two axle. It is. V nose. 6' wide inside and 7' tall inside if I remember correctly.
