new enclosed trailer.
jekjr
I'm going to try to install some racks on Monday or tuesday. But the walls on the inside of the trailer is wood from the floor all the way to the ceiling. How do I locate the studs? Buy a big magnet or what?
all you have to do is locate where the screws are that holds the ply wood in place and line up there.
We are in our second year of using an enclosed trailer. It has a lot of pros and some cons I guess.
Hauling as much equipment as we haul and unloading as much as we do ours has taken a pounding. I plan to try to make one more year with the one we have and then look at possibly updating to one that is a little heavier.
Mine is 16' two axle. It is. V nose. 6' wide inside and 7' tall inside if I remember correctly.
zmister11
Yeah i got then installed a few days ago:)
zmister11
Thanks! I want the Hi-vac. Just can't find much info on how well it mulches with Ninja blades.
Ur welcome! Mine doesn't seem to mulch leaves very well. Just grass if your cutting short grass
