ok I have rebuilt the carb. It has spark but will not start, not even try to start. How do I check the coil to see if it is making enough spark to fire engine? I have disconnected the ground and it is making spark. All wires seem to be fine. Its sparks when switch is in the on postion and will not make spark with the switch on the off position. I think spark is weak. Freaking coil is 81.00. I need a way to test strength of spark. How do I do this. I have a tester yes its a good one. Please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
