Shughes717
- Jun 12, 2014
- 1,230
All you have to do is look at and compare the spec's to see how it can be built heavier and weigh less, I've already gave you some reasons or examples. The Snapper frame is a 2 x 1.5 11ga frame. The Toro is a 3 x 1.5 10 ga. it's larger and heavier, look at the spec's. As far as how I know how Snapper and Ferris are built is the fact I've seen them on the showroom floor at the dealers, I've looked at them, I've set on them and compared them to the Toro just like I have the Gravelys and Scags and Cub Cadet and a few others and the only mower that even comes close to the build quality of a Toro ZM IMO is a Hustler X One and up. I talk about frame relating to the ride of the mower, the heavier the frame the better the ride, I'm not worried about a frame or a lift system breaking. The thing is really it doesn't take some one with a degree to look at and compare two or three different mowers and tell which one is a better built mower and which is not. :smile:
Thickness of frame has nothing to do with the ride of the mower. Tire size, space between tires, weight, and suspension does. Z master doesn't even compare to the ride of an is2100. Instead of just looking at them on the show room floor you should demo one without bias. Toro doesn't show the dry weight of their mowers on their site. Heavier metal should weigh more. If it's built with more metal it should weigh more. Doesn't take someone with an engineering degree to figure that out.:smile:
