Hi Ken,
This is the best that I can do.
Things that you will need:
A jack to raise up the right rear of the machine.
Sockets, open end or combination wrenches to fit all that need to be removed/disconnected.
Pliers and a Chanel Lock pliers to remove the 1 3/8" nut holding the hub onto the wheelmotor shaft.
Blocks of wood to hold the machine after jack is removed.
What to do:
If you have a digital camera, take pics as you disassemble for wheelmotor removal to assist you in reassembling. Clean the areas that you will be working around, you don't want dust/dirt getting into the hydraulic system.
With parking brake on, break loose the four wheel lug nuts, but don't remove them yet.
Jack the machine up and place wood support blocks under the machine frame support that is between the rear tire and the aft corner of the deck. This block(s) need to be large enough and long enough so they will stay in place should you move the machine while attempting to remove the hub. Let the jack down so the machine rests safely on the block(s). I have a piece of 4"X6"X12" long cut specially to do this so I have only one block.
Remove the tire/wheel assembly. Remove the cotter pin and large nut that hold the hub on.
Release the parking brake, remove the brake band and reinstall the tire and wheel assembly, put the four lug nuts back on hand tight.
While pulling on the tire as leverage, attempt to slide the hub off the wheelmotor shaft.
If this doesn't work, then remove the tire/wheel.
Using two prybars, pry under the drum of the hub and hopefully be able to remove the hub from the shaft. Remember that moving the machine while it is sitting on the block(s) can be risky and you don't want the machine to fall off the support blocks!!!
If you are successful in removing the hub, then the wheelmotor will be next. Remove the pin from the brake linkage, remove the two bolts holding the brake actuator, lay these parts aside. Mark the hoses before disconnecting them and get a drip pan to contain the hydraulic that will drain from the hoses when disconnected.
Disconnect the hoses from the wheelmotor, use two open end wrenches, one to hold the fitting in the motor and the other to turn the nut on the hose fitting. Place drip pan under wheelmotor. Cap the hoses and motor fittings.
If you get to this point successfully, then remove the two remaining bolts/nuts holding the wheelmotor onto the frame.
Reading this should have given you a headache by now!!!!
If you are still not able to remove the hub, you can still remove the wheelmotor with the brake actuator still under the hub and the hub can be removed on a press at the hydraulic shop. However this makes disconnecting the hoses a bit more difficult.
Good thing that my Tiger Cub is sitting in my shop so I can look at it as I type this to you!!! Now I need a nap, typing this is more tiring than actually doing the job!!!:laughing:
Mad Mackie in CT:laughing::biggrin::smile:
