http://bsintek.basco.com/BriggsDocumentDisplay/jgEDGP_ctP8tG6EPi7mRgtLvBCd6.pdf
http://bsintek.basco.com/BriggsDocumentDisplay/jgEAGP_cuJ4tG6EPi7mRgtLvBCd6.pdf
Post your model number example: 1692454
Replace fuel filter, air filter, spark plugs & check oil level on dipstick and if gas is in oil by checking dipstick.
Model 1692454
20 hp Kohler Command
replaced fuel & air filters
oil level full and clean
no gas in oil
starts with no hesitation then stalls within 4 seconds. Every time.
Model 1692454
no gas in oil
check circuit breaker, wires grounding out from electrical harness, or defective safety switch, use hands on approach & take your time.Thanks for wiring diagrams.
Engine was replaced with Kohler by previous owner. No start/run problems until now, 5 years later.
Found that fuel solenoid isonly energized during cranking. Is not energized in run position of ignition switch. Safety switches all made and energized. Don't know where to look.
