Simplicity Sunstar 20 HP Kohler Stalling
jcj54
My 1997 Sunstar starts every time I turn the key. BUT then it stops like shutting the switch off within 3-4 seconds. Help!
jcj54
http://bsintek.basco.com/BriggsDocumentDisplay/jgEDGP_ctP8tG6EPi7mRgtLvBCd6.pdf
http://bsintek.basco.com/BriggsDocumentDisplay/jgEAGP_cuJ4tG6EPi7mRgtLvBCd6.pdf
Post your model number example: 1692454
Replace fuel filter, air filter, spark plugs & check oil level on dipstick and if gas is in oil by checking dipstick.
Model 1692454
20 hp Kohler Command
replaced fuel & air filters
oil level full and clean
no gas in oil
starts with no hesitation then stalls within 4 seconds. Every time.
mechanic mark
Model 1692454
no gas in oil
Lawn Tractor Manuals | Riding Mower Manual | Simplicity Mowers Manual shows 20 h.p. being B&S Vanguard & 18 h.p. Kohler Command. Either way you need to adjust valves to specs. Post all numbers from engine. Check neutral detent w/safety start switch.
Lawn Mower Parts, Small Engine Parts & Much More! | PartsTree.com - Briggs, MTD, Toro, Cub Cadet, Husqvarna, Troy-bilt...
jcj54
Thanks for wiring diagrams.
Engine was replaced with Kohler by previous owner. No start/run problems until now, 5 years later.
Fish
Yeah? Kohler numbers????
mechanic mark
check circuit breaker, wires grounding out from electrical harness, or defective safety switch, use hands on approach & take your time.
let us know what you find please.
jcj54
Found that fuel solenoid isonly energized during cranking. Is not energized in run position of ignition switch. Safety switches all made and energized. Don't know where to look.
mechanic mark
