william j smith jr
- Sep 6, 2014
- 4
I have replaced the drive belt, I have replaced the pto switch , (and the blades engage when the engine is running),,, I have checked the back pull leaver to make sure the mover drive is engaged and is not in the push by hand position. The mower will start,,, the blades will engage,,, but the mower will not move forward or backward. Anyone ever have this problem?
I am presently going to get a 20 amp fuse because I just blew the one that was in it. What could be causing this mower not to move forward or backward.
The back drive is sealed and there is no place to add hydrolic oil ,,, and there is no way to check the levels,,, When inspecting the back,,, there is no excess oil on the outside leading me to think that the rear end is leaking any hydrolic oil.
Any suggestions?
Any suggestions?
