On a sort of related note... What does SUP and PRI stand for in the Honda parts break down description?
One final question. The pads on the drive disc have tiny cracks. Is that normal? I am going to replace it, but maybe they all get that way. Just curious.
That is a 10 x 25 mm hex bolt; Honda says to use a normal torque, which is 29 ft-lbs. (39 N瀕).
Ideally, you should use a strap wrench to hold the flywheel. I recall you may also be able to temporarily fit the blades and their bolts into place, then used a 2 x 4 or other block of wood stuffed into the discharge to hold the crankshaft in place...
Just to clarify for accuracy in the future. I just Recieved the shop manual and the correct torque for that bolt is 40 ft-lb, same as the blade bolts.
