HRC2163HXA MAKA 1094141 Blade Clutch Assembly Bolt Torque Specs
Koamolly
Does anyone know the torque spec for the bolt that holds on the blade clutch assembly? This is for the one bolt in the center, not the two bolts that hold on the blades. Also, what's the best way to stop the engine from rotating when tightening the bolts? Thanks.
Hold the flywheel with something. And tighten it as much as you can by hand don't break it tho
That is a 10 x 25 mm hex bolt; Honda says to use a normal torque, which is 29 ft-lbs. (39 N瀕).
Ideally, you should use a strap wrench to hold the flywheel. I recall you may also be able to temporarily fit the blades and their bolts into place, then used a 2 x 4 or other block of wood stuffed into the discharge to hold the crankshaft in place...
Just be careful doing that that's a lot of torque on one side of the blade
Interesting, that's lower than I thought since the the owner's manual has 36-43 ft lbs for the blade bolts. I assumed they would be the same. Thanks.
The blade bolts are made of a different material, and use special curved washers. They are subject to considerably more stress and must only be tightened to a precise torque for safe, reliable operation and blade retention. Thus, we have a a "special torque" spec for them.
Other "regular" bolts, nuts and fasteners on modern mowers are in different league for stress and operational performance, and are not subject to the type of demands required of a blade bolt, so the torque specs are SAE standard instead.
I'm having trouble following your logic since Honda recommends using a wood block when installing the blades which require a higher torque.
That's to stop the crank from spinning. You have your crank shaft which is perfectly balanced, and let's add your blade that is 21" long you stop one side of that blade with wood block and you begin torquing the crank bolt if you put to much pressure on one side of the blade 10" away from the crank you could bend the blade or even the crank . Granted you should be done tightening long before we get to this point some people don't know there own strength and could bend the crank ruining the entire motor.
I retorqued the bolt. I don't think blocking the blades works since blade clutch is not engaged. I did try blocking but the crankshaft still easily rotates. Unless I misunderstood.
Ahh yes blade clutch. The real best way is to either engage clutch and use the block or the best way is strap wrench the flywheel
