Kwelhand
I use Dewalt 1/2" cordless impact.
Extremely compact and very powerful.
Used on heavy rusted blade bolt removal w/ no problem.
Amazon.com: DEWALT DCF880B 20-Volt Li-Ion 1/2-Inch Impact Wrench Kit with Detent Pin: Home Improvement
Wow all these fancy tools and I just use a 2x4 wedged between the blade and deck. It has never not worked on any mower with a blade.
That's the reason I built the blade blocker. The 2x4 never wanted to stay where I put it until pressure was applied and I got tired of chasing it.Wow all these fancy tools and I just use a 2x4 wedged between the blade and deck. It has never not worked on any mower with a blade.
I use a 1/2 in. Air Impact Wrench / Gun. Never have a problem removing a blade bolt or nut.
Well I never thought about it like that. I have to use 2 hands in awkward places to get started.
I found it to be easy on the rt. and center blades of a 3 blade and on the left blade position the blade 90° to tractor length and put the blocker extended out to the center by feel or visually install through the discharge chute. You'll soon find what works best for you and your mower.
