My Craftsman GT5000 deck is at maximum cutting height and my Truegreen rep said to cut grass at higher level. Several people have checked the tractor/mower and said there is no more adjustments to make. Has anyone solved this problem?
My Craftsman GT5000 deck is at maximum cutting height and my Truegreen rep said to cut grass at higher level. Several people have checked the tractor/mower and said there is no more adjustments to make. Has anyone solved this problem?![]()
Try that on lawn tractor tires ( both front and rear ) and report back the circumference differential.Easy way. Just add 5psi to each tire. Will give you about half inch
OH NO , I never say anyone is wrong. They are just required to prove to me they are right. :laughing: So go ahead and give me the circumference numbers from the 5 lb. increase and I'll calculate the diameter difference .I have tried it on many lawn tractors.
Are you trying to say I am wrong ?
First step to level a deck is make sure all the tires have the psi they should.
I guess we can skip this step from now on.
Now that we have been told that the psi in a tire does not affect the ride height.
