Jefe...
have you checked all your battery cable connections, are you measuring this large voltage drop on the battery? If so try to give it a full charge, check the water level first, If this is a serviceable battery...
You can't expect much more than 2 to 3 years from the typical lawn mower battery, so there may be a new battery in your near future...
:smile:KennyV
Can you confirm whether that an excessive voltage drop?
Going from 13 to 6, sounds like a bad plate or two, and you just aren't getting the amps......which would mean a bad battery. The initial charge of 13 sounds good, doesn't it, Kenny?
Way too much of a drop... 6 volts is not going to do it.. Were you able to put a charger on it?
:smile:KennyV
Well ALOHA FROM HAWAII! MY NAME IS KALAUKIA37. I AM A NEW MEMBER AS OF TWO DAYS AGO. I LIVE ON OAHU IN HAWAII. I HAVE A J.D. 42 115 AUTOMATIC, 2006 YEAR. I HAVE FOUND OUT THAT IF YOU BUY AN INTERSTATE BATTERY WITH THE HIGHEST AMPS POSSIBLE, AND THAT YOU KEEP IT ON A VERY SMALL TRINCLE CHARGER THAT CANBE BOUGHT FROM NAPA FOR ABOUT $39.00, IT WILL PAY FOR ITS SELF FOREVER. IT WILL KEEP YOUR BATTERY FULLY CHARGED FOREVER. YOUR BATTERY BYes. The battery was stored for the winter and I had re-installed it and charged it overnight prior to trying to start the mower with it.
