Carscw
The oil problem was likely the head gasket, why it won't start is another one altogether. This has been a long and convoluted thread full of bad advice. When was the last time the engine ran and smoked badly??? Detail the next several steps...
It seams as every thread is full of bad advice if everyone does not bow down to you and what you say.
If you knew anything about engines and could build your own with out a book then you would know why my way of adjusting valves works.
Just because someone does not do something the way you do does NOT make their way wrong.
