ProTechCharlie
- Jun 13, 2014
- Threads
- 3
- 42
Ok, go back to the very first scene of your latest video, where the piston is at tdc and both valves are down.
With everything in that position, take your thumb and try to rotate each valve. If you can, then that is a major problem.
Also, it looked like you needed a tool to rotate the engine with the head off, is that true???? The thing should rotate like greased lightening.
Yes sir. Very much needed a screwdriver in between the fins. Is that a problem? I tightened the connecting rod bolts to right before the point where they would not move anymore. Also, there was some horizontal play in the crankshaft when I put it all back together.
As far as the valves moving, they both move, but I must apply much torque. I would say that to get the exhuast one to move, it hurt my thumb and it turned red. For the intake, I had to use the palm of my hand and after the few moves, my thumb was able to move. You say the exhaust valve doesnt look like it is closing, I will have to remove the spring and valve grind it? Then compress the spring? Can I do that with a pair of need-nose pliers, or do I need to get a tool when I get the gauges? Or, is it a possibility that the rod is bent? And how did my cylinder look? Enough to keep compression?
-Thanks, charlie.
