ProTechCharlie
- Jun 13, 2014
- Threads
- 3
- 42
If spark is weak then that could possibly be your problem. I have my doubts from looking at your video, though.
Actually compression can be low and still have enough to pull in fuel. I have the 130202 on a tiller and at 30psi compression it sent a flame(backfire) out of the carb.
I don't mean to question you, but you think my two videos show I have enough spark to start the ignition and have combustion? I just don't know, I mean, I would think that even the smallest spark would set off those fluids. Especially ESF or gas. I put carb cleaner in the carb, and I tried to start it, and it got really close, to the point where it was almost spinning by itself, and that is what makes me think of weak spark, but at night, and when I hold onto it, it seems to be enough? Maybe it just looks like enough? Your thoughts? I also apologize if I sounded offensive towards you in any of my posts, that wasn't the intention.
I'll try to stick a compression tester on it tomorrow. See if they have one I can use at an auto parts store. But what would cause my leak? I've went either checked or replaced (replaced most) of the common compression failure causes. Your thoughts on this as well?
-Thanks, Charlie.
