I may have missed it but what is the compression at?
I have not tested it. But, I have
many reasons to believe that it has good compression.
1) It is difficult to move without the pull start attached (by hand).
2) I can hear it.
3) Put my finger in the plug hole and it blew past.
4) Installed new rings.
5) Installed new crank case gasket.
6) When I take the head off after trying to start it,
I CAN SEE GAS ON THE VALVES AND INSIDE THE HEAD!!!!!!!!!!
7) Valves open and shut according to piston position and there is no overlap between the intake and exhaust opening and closing.
The sixth point leads me to believe Fish. Because, gas from the tank would not be in the dry head, if it did not have enough compression to suck them in. (I know it was dry because I installed the tank when the head was 100% dry). I have poured gas, ESF, and carb cleaner right in the head, and
NOTHING!!! I think the spark is so weak that it is unable to ignite the combustible fluids. But it gives me a good little jolt when I pull the starter, which leads me to believe that it is providing enough current.
