240addiction
- Jun 8, 2014
- 5
I bought a hrx217hxa on craiglist that sounded like it had a knock of some kind(I also got a hrb217tda and a hrx217tda for 250 total). The previous owner was not sure what happened, but the knock was most noticable at low rpm and did not change if the the blades were enabled. I figured it was a rod knock and decided to pull the mower and see if I could figure out the issue with it. Well I got it apart tonight and found the following.
[/URL
[URL=http://s209.photobucket.com/user/240addiction/media/20140611_220314_zpsrqmje4nl.jpg.html]
So the crank looks like it may have had too much run out on the top and the in and out play was over the allowable amount. Does the groove on the cylinder barrel look like it wore quite a bit? My main question is if this is worth rebuilding or should I try and find a used motor. Parts look like they will be 160 or so. So far what I will need are the cylinder barrel, crank, piston, rod and rings. The oil pan looks fine IMO.
Thanks
Paul
[/URL[URL=http://s209.photobucket.com/user/240addiction/media/20140611_220314_zpsrqmje4nl.jpg.html]
Thanks
Paul
