JDgreen
- May 14, 2010
- Threads
- 248
- 2,887
I first saw this at BB and it seemed OK... then it came up on Woot for less than $400, so I figures I has to get it...
I have never has much laptop use time, I will keep that battery drain time in mind...
It has a 6 cell batt, just a tad end heavy, but run time looks very good, A friend was using it the other day and got just a little over 5 hours on it, took it down to 8%, she got a little worried and shut it down because it recommended a plug into power... Didn't have an AC power source at the time... :smile:KennyV
Your friend did the right thing by shutting it down, these big screen models slurp up the last of the juice very fast....they will usually shut themselves down when the battery power gets low enough IF things go right but if not you will have complications upon the next boot up. 5 hours is an excellent run time for a 17.3 screen my Toshiba struggles to make 2 1/3 hrs on battery power.
