Carscw
I really want to see this. I mean, if it is a good repair, I will laud you all over and give you all of the credit... But these bearing failures usually involve bent parts/blades anyway, and the spindle was made to just be swapped out, unless you were a teenager with a whole lot of time on his hands, well.........
Why would bad bearings involve bent blades and parts?
Are you really telling me you have never replaced spindle bearings?
Changing bearings takes no longer then changing blades on most mowers.
Hardest ones are toro because they are held in with clips.
