I bought a new HRX217HYA last year, forgot to put stabil in the tank for the winter.  Result: surging.  Ordered new carb and put it on but now engine will not fire.  I have drained all fuel and replaced with ethanol free fuel but no luck.  It was the correct carb for that engine and it is getting fuel - spark plug has fuel on it.  Any suggestions to get this thing back up and running?  Trying to avoid the dealership since this is prime time and they are 2.5 weeks out.
Confirm the choke plate is fully closed when the engine is cold. The HYA has an autochoke system, which uses a spring to hold the choke closed. After the engine warms up, a special wax inside a small cylinder expands and pushes the choke fully open. The linkage (pink) must move freely and on cold engine, hold the choke closed. Here's how to inspect it:
Honda recently issued a Service Bulletin to address this problem; some HRX and HRR models may benefit from an improved choke control assembly (green),
if the current one is binding. You can see if your mower is part of the update by checking the frame serial number on the back of the mower deck. Affected models for the HRX217 include:
   MAGA-2069726 through MAGA-2199999
   MAGA-2200001 through MAGA-2325178
If you determine the choke is
NOT working properly and the choke control assembly
IS binding, a Honda dealer must confirm the problem to authorize installation of a new choke control assembly (and wax cylinder) under warranty. It is a bit of a procedure to properly install the updated choke control assembly, including correct application of some special sealant to ensure proper heat transfer from the cylinder head to the wax cylinder.
If the
choke is working properly, double-check the four gaskets//guides (yellow) and confirm they are installed in the right position and location. Make sure the two long bolts holding the carb on are secure (either could cause a vacuum leak and result in no-start).
