Putting a jumper cable directly on the positive terminal of the battery and starter... Then try it again with the negative jumper on the starter base and the other on the negative terminal. If your battery and starter are new, the starter should crank like it is new....
you may want to test the starter. yeah, its new, but could still be faulty.
