Need Help Finding New Carburetor For My Pushmower
ThatRandomGuy
Okay, so I need to get a new carburetor for my push mower because this one is too far gone. I'm having a problem finding the carburetor online though and thought I should ask if anyone knew where I could find this particular carburetor.
My pushmower model # is:
961330003 00
Serial is: 070706M 017299
it has a 21 inch cutting radius as well.
I did look at the carburetor and found a code its: 62ZWTLO7
But I googled it and couldn't find anything on the carb.
Thanks for all help in advance!
Also here is a picture of my exact mower I found:
http://s571.photobucket.com/user/ioilyouin/media/Insurance Pics/DSCN2873.jpg.html
You need to tilt it back and look at the metal cover above the spark plug, under the plastic cover, and give us all of those numbers.
ThatRandomGuy;150498 Also here is a picture of my exact mower I found: [url=http://s571.photobucket.com/user/ioilyouin/media/Insurance%20Pics/DSCN2873.jpg.html said:
Husqvarna Push Mower Photo by ioilyouin | Photobucket[/url]
That appears to be a Honda GCV160 engine; Honda sells a LOT of mower engines to Husky and other mower companies. From the photo, it appears the carburetor is a fixed-throttle, AutoChoke design, as there does not appear to be any cables (throttle / choke) connected to it.
You can get a carb for it (pretty cheap, probably under $25) but first need the engine serial number off the side of the engine block. It's etched in and could be hard to read, but will be in the form of either 4 or 5 letters followed by a 7-digit number.
With this serial number, you can look up parts online (just google Honda Engine Parts) and you'll find Honda dealers who sell parts online. Parts catalogs will be arranged by the engine serial number. You may also wish to contact your local Honda dealer, who can also help you get the right carb when you give them the engine serial number. Here's a link to find a local dealer, who may actually be cheaper than online, when you figure shipping...FYI...
Find A Honda Dealer
Find A Honda Dealer
Okay I think I found it it says:
GJAEA 4527407 S3A(THEN SOME STAR THING)
