Fish
No, you just bolt the whole engine on the straightener, take the plug out, and wire the blade brake so you can rotate the crank, takes about 5 minutes to straighten it.
Check around some of your older mower shops, They likely have one up in the attic under a pile of dust, they might sell it to you real cheap.
