Eugene Onegin
No it won't the grass has to cut regardless.
Well March would be the third month of the year so I guess they observe that as quarterly. Ya know you really need to cut those company's some slack, I believe it was Exxon that only made 54.4 Billion in profits in 2010, they need the money :licking::wink:
Our local newspaper had a story yesterday saying because of the unrest in Libya, the price per gallon may hit $5 by summer. Diesel of course will be even more costly. I would cut back my mowing but I already let it go too long between mowings because my lawn is so huge. The irritating thing about my mower deck is that it doesn't chop the clippings up very well and the longer I go between mowings the worse the rows of uncut clippings get. I should try to find some new blades that will do a better job of chopping the clippings up. Anybody have experience with a good replacement blade for a JD 7-Iron deck? Mine still has the OEM set.
I have a 52" dedicated mulching deck (no discharge or bagging) that I use during the "slower" growing months. If I try to cut grass that has grown more than normal in one pass, all I do is create creamed spinach out of it. Generally wind up cutting in multiple passes to get a decent job. Side discharge deck with gator blades does not retain the clippings long enough to chop them verry fine. Best cuts are with standard bagging deck, I added an oversized collection blower to enhance packing the clippings which workes well.
My unit is diesel powered, It gets twice the running time on a tank of fuel, as my water cooled F.I. gas engines do.
Same gallonage tanks. Even with the price of diesel being more the actual operating costs are half.
I just took delivery of a set of JD Gator mulching blades from an Ebay seller, the guys on TBN recommended them to me when I posted about needing a blade that would cut the clippings better.
I am running Gator mulching blades that are made for John Deere, on my CTL side discharge...
They cut things very fine... I almost always cut running clockwise, and re-cut my previous discharge:thumbsup:... that way even when I'm in tall grass it gets mulched to very short clippings... :smile:KennyV
