Fish
- Aug 2, 2013
- Threads
- 11
- 5,131
So, as a mechanic, you would just "slip the pawl back in"?
And that is a good repair that a "Mechanic" would do?
No a good mechanic would dis-assemble it completely, and clean and replace all of the worn parts so the part functioned as
it was meant to.
The most likely worn out spot on that starter is the pockets where the pawls ride, which would require you to replace the plastic pulley, which is only sold with the spring, and on this outdated model costs @ $25, as that starter is no longer made,
replaced by the model with the bolt in the middle instead of the roll pin.
Now you can buy the new starter for $21.15 and just bolt it on and be done, or totally disassemble everything and buy a
new pulley/spring for @25$, what would "an intelligent mechanic" do????????
OEM Parts
it was meant to.
OEM Parts
