bgarfinkel
I'm looking for a recommendation on a lawn vacuum and have narrowed it down to either the Echo ES-250 ($229.99) or the ES-255 ($329.99).
ES-250 - ECHO ES-250 Easy Starting Leaf Vacuum Leaf Blower Shred N Vac - ECHO USA | ECHO USA
ES-255 - ECHO ES-255 Easy Starting Leaf Vacuum Leaf Blower Shred N Vac - ECHO USA | ECHO USA
Both appear to have metal blades.
Both have the same sized engine (25.4 CC)
The only real difference I can see is that the ES-255 comes with a nicer top handle, the i30 start system, and a blower tube that is pinched at the end instead of round.
ECHO Shred 'N' Vac ® Comparison | ECHO USA
I will not be using this commercially.
Does anyone have any recommendations?
Thanks.
Thanks.
