MowerMike
The only thing I can see that priming would do is to force more gas into the cylinder to burn and it would burn for a short period.
The primer bulb does not pump gas into the engine. It pumps gas into the carb only, purging it of air, and excess gas is returned to the fuel tank. Giving it throttle OTOH, especially with the choke closed, will definitely flood the engine. Some carbs have a fuel screen, which if clogged will prevent gas from entering the engine, which may be the problem here. In that case, the carb must be disassembled to clean it.
