MowerMark
- Mar 1, 2014
- 339
RECENT THREAD: http://www.lawnmowerforum.com/small...allation-honda-mower-few-other-questions.html
This abnormality hasn't happened in there weeks, but used to happen half the time on start-up, but never when the engine is hot: The engine starts with one pull, but runs at 10-25% speed, shakes, is louder, and the exhaust spits out smoke. I then turn off the engine, restart it, and if the problem recurs, repeat the sequence. After one to five of the these sequences, the problem goes away? the engine speeds up, and there's no visible exhaust. I called a local mower shop and the man said "your automatic choke must be sticking".
This problem has not recurred in the past few weeks, but thought I'd still post about it here to see:
1. What is causing this ?
2. Why doesn't it occur every time ?
3. Why does it seem the problem has gone away ?
4. Is damage being done when the engine malfunctions like this ?
5. The mower is still under warranty. Should it be submitted for repair at a time when the problem is not occurring ?
6. Is this issue something a simple homeowner could diagnose or treat ?
