exotion
Thank you. Do you have a picture or diagram of that HRR screw area ?
Not sure if my has a micro cut or quadrant cut. How does one distinguish and are both these blade types acceptable on my mower model ?
The micro cut are the offset blades and quadracut are the stacked blades swing by home depot pick up a box 30$ says they are for the hrx but I've used them for a long time no issues. There is only one piece of sheet metal like mentioned before tip the mower down carb up. Get leather gloves manually spin the blades see if it touches anything. Wiggle the sheet metal see if it moves at a if so there will be a empty screw hole
